Hello Guest it is October 19, 2026, 11:21:05 AM
Author Topic: reveresing + & - in z  (Read 12306 times)
Offline greg
  •  66 66
« on: January 18, 2008, 09:21:08 AM »
  i have done this before but i can not remember how. when i push the page down key my z moves down but it reads +. how do i change this? thanks in advance greg
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: reveresing + & - in z
« Reply #1 on: January 18, 2008, 10:17:16 AM »
Hi, Greg
In home & Limits, Use the Reversed column, X or checked.
That will do It, Chip
Offline greg
  •  66 66
« Reply #2 on: January 20, 2008, 10:40:42 AM »
when i reverese then page down makes it go up so it reverses the direction. i had it going down ok but the dro read +. thanks greg
« Reply #3 on: January 20, 2008, 11:14:01 AM »
You can reverse the axis by checking or unchecking the Dir Low Active setting but this can have adverse effects on some drives, wont harm them but they just wont work properly.
 Your other option is to go to the Config Menu then down to System  HotKeys, click on the Z++  press the Pg Up on your keyboard, then do the same for the Z-- this time pressing the PgDn key. This will reaign the keyboard buttons the correct way for you.
Offline greg
  •  66 66
« Reply #4 on: January 23, 2008, 05:53:18 PM »
thanks hood, sorry it took so long to get back to you. i just got to do as you said, all works well now. thanks again greg
