Hello Guest it is November 22, 2026, 04:00:51 PM
Author Topic: Look ahead above 2 can cause G0 Feed-hold/Cycle Start Issues Position Loss  (Read 12882 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Hi, All
Mach3R3.01 is on line, It Has a couple of Issue's.
Wait till tomorrow, When this Msg. is Deleted or Edited to download.
Yahoo mach1mach2cnc group is down at the moment, Posted some info for Brian just before it went down.
In the install location has a space between the C:\Mach 3 should be C:\Mach3.
I now in the past there has been a install path C:\Mach3R183.##.... that had to be edited to Mach3 sometimes.
Mach3R3.01 has a fix for a feedhold problem, There seems to be an Issue with position after a feed hold In G0 move,
It's losing position on next Cycle Start.
Thanks, Chip
« Last Edit: January 08, 2008, 01:42:00 PM by afn09556 »
Chip,
I have fixed the install program and I will work tonight on the code to fix the feedhold. That, I think is going to take the night and I am not sure that I wil be able to finish it :(
Brian
« Last Edit: January 08, 2008, 01:42:58 PM by afn09556 »
www.newfangledsolutions.com
www.machsupport.com
Chip send me your Gcode file please... I can not seem to get the same problems.
thanks
Brian
« Last Edit: January 08, 2008, 01:43:23 PM by afn09556 »
www.machsupport.com
Offline Chip
  •  2,055 2,055
Hi, Brian
Was up late last night till 5:00am
Hears the code
Thanks, Chip
« Last Edit: January 08, 2008, 01:43:48 PM by afn09556 »
Offline Chip
  •  2,055 2,055
Hi, Brian
After looking at this further, Look ahead above 2 can cause G0 Feed-hold/Cycle Start Issues  Position Loss.
Seems to skip cuts or double cut them. Hears a picture with 3 in look-ahead
Thanks, Chip
« Last Edit: January 08, 2008, 05:49:15 PM by afn09556 »
