Hello Guest it is November 02, 2026, 05:56:42 PM
Author Topic: crank shaft  (Read 20750 times)
crank shaft
« on: December 29, 2007, 04:08:34 AM »
i am trying to make a crank for a small 4 stroke engine i have drawn up the crank with rino and when i try to generate the g code in rhinocam it is cutting the crank part off & leaving a spindle in the centre can anyone help
Re: crank shaft
« Reply #1 on: December 29, 2007, 09:07:29 PM »
Can you post a pic.?  You know what they say, a picture is worth a thousand words.
Re: crank shaft
« Reply #2 on: December 30, 2007, 04:38:17 AM »
hi thanks for the reply i hope you can throw some light on this
mick
Re: crank shaft
« Reply #3 on: December 30, 2007, 04:44:02 AM »
cheers
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: crank shaft
« Reply #4 on: December 30, 2007, 08:24:41 AM »
Are you trying to make it on a lathe or a mill?
Graham.
Re: crank shaft
« Reply #5 on: December 30, 2007, 10:52:24 AM »
i am trying to make it on a taig mill with a 4th axis i have posted the code that rhino cam is producing im just toataly lost
  •  2,785 2,785
Re: crank shaft
« Reply #6 on: December 30, 2007, 12:46:52 PM »
Email me a .iges file of the part and lets have a look at what can be done.
Graham.
  •  2,785 2,785
Re: crank shaft
« Reply #7 on: December 30, 2007, 01:43:56 PM »
Looking at the NC code you posted it looks like you are roughing from the wrong side, rotate the datum onto the opposite face and work from that side.
Graham.
Re: crank shaft
« Reply #8 on: December 31, 2007, 03:40:37 AM »
here is the .iges file you requested i do appreciate you time & helping a novice in this area
mick
  •  2,785 2,785
Re: crank shaft
« Reply #9 on: December 31, 2007, 07:55:11 AM »
Ok, this is how I would do the first op.
Datum is on left hand end for X axis.
Y and Z axis are on indexer centre line.
Using a 1/8" end mill.
I would try it on a bit of wood or plastic first.
Material is 1.375 square or round, by length of job plus what ever length you need to clear the indexer with the head.
Graham.
« Last Edit: December 31, 2007, 08:04:41 AM by Graham Waterworth »
