Hello Guest it is September 29, 2026, 01:41:54 AM
Author Topic: M3 Turn Spindle rpm/timing  (Read 34824 times)
« on: December 27, 2007, 10:54:34 AM »
I updated my Mach 3 to the newest version and I lost my spindle speed rpm. It will only read up to 200. It should read up to 2,100. If I activate my indexing and timing at the same time and at the same pin number, it will read my rpm correctly on the main screen but it will not cut the threads correctly. I have to reinstall the older version on Mach 3 to be able to use my threading feature. Right now it is set on index port 1 pin 10. I really like the new feature in the latest version and would like to find a way to be able to use my indexing or timing. Please help me to figure my problem. Thank you very much.
