Hello Guest it is October 21, 2026, 12:54:58 AM
Author Topic: The new Upgrade doesn't like Arcs.  (Read 10251 times)
« on: December 23, 2007, 12:21:59 PM »
Boy what a mistake.  I upgraded to the newest mach release and now The problems begin.  It doesn't like mach2/3 Arc (inch).txt .  It loads with a hole bunch of circles on my g-code> but when i just select mach 2/3 (inch).txt the g-code loads normal.. any help on whats going on would help me out allot... ??? >:(
Re: The new Upgrade doesn't like Arcs.
« Reply #1 on: December 23, 2007, 01:32:13 PM »
Go to the general Config page (from Config menu) and swap the IJ mode to see if that helps. If not then can you post pics and code so we can see what you are meaning.
« Reply #2 on: December 23, 2007, 04:37:35 PM »
Thanks hood that worked.  What exactly is that fubction going to have to read up on it again get a little more indepth..
