Hello Guest it is September 09, 2026, 07:37:59 AM
Author Topic: Anybody notice that Limit Switch Trigger "De-References" Machine?  (Read 15613 times)
I'm Runing Ver 2.61.  Between parts I'll drag out the shop vac and clean up the table.  Somehow while wrestling with the hose I'll trigger a limit switch. No Biggie- I hit reset and all is OK except I get a "abnormal condition" alert= Machine axis not referenced.  I already referenced.  Is this just me?  If not, anybody know a 'workaround'?
Thanks in advance for any/all replies.
Oh, BTW- Happy Kwanza!
Sid
Re: Anybody notice that Limit Switch Trigger "De-References" Machine?
« Reply #1 on: December 21, 2007, 08:12:13 PM »
Hey Sid, Do you think it is a static shock throwing the limit and causing your troubles. I haven't seen that message. If I hit a limit that puts Mach in a reset condition, I would rehome regardless. Any time a limit is triggered, it is allways a good idea to rehome. This is true even in the large industrial CNCs.
Merry Christmas,
« Reply #2 on: December 21, 2007, 10:52:50 PM »
Hey Brett,
Thanks for the reply.  Don't think it's a static problemas this issue has just surfaced recently (in conjunction with one of the recent updates).
I agree with you though- I rehome frequently through the course of the day but, it's just a bit of weirdness that I was wondering about.  Clicking the Reset button does not cause this- just triggering a limit switch.
... things that make you go "HUH?"
« Reply #3 on: December 22, 2007, 02:58:26 AM »
I think it is normal when a limit is triggered that Mach will lose its reference. If you think about it when a limit is hit Mach will cut everything but momentum could make the axis travel a bit more before it stops. Mach has no way of knowing where that axis now is so it tells you its not referenced. I am not at a machine now so I cant say 100% this is the case but 99% sure this has always been.
« Reply #4 on: December 22, 2007, 01:01:45 PM »
Hmmm...  I think you are right.  It's kind of a forced reminder to re-ref your axes.  It's just wierd that I can't remember it ever doing that before (maybe I never noticed  ::) )
Offline bowber
  •  216 216
  • Kirkby Stephen,Cumbria, UK
« Reply #5 on: December 22, 2007, 02:57:15 PM »
Mmmm, that abnormal condition light always flashes on my system whatever, never had it go out.
« Reply #6 on: December 22, 2007, 03:03:00 PM »
If every thing is as it should be then double click the Abnormal Condition button then click Yes and it wont flash again unless something changes.
Offline SimonD
  •  143 143
« Reply #7 on: December 25, 2007, 02:47:24 PM »
Don't know if this helps at all...
I tend to hit the STOP button before trying to hoover out my machine just in case I hit the limit switches. That way it doesn't reset the system and I don't have to re-reference.
