Hello Guest it is November 16, 2026, 07:06:28 AM
Author Topic: new setup  (Read 9289 times)
new setup
« on: December 20, 2007, 11:24:00 PM »
hi all a newbee here,
is there something i am missing in the setup of this program, i have just installed it and setup the port to suit a xylotex driver board and cant get any movement at all.
the diagnostics show no pin activity at all. does anyone have any idea what ive done wrong?????
windows xp pro
xylotex 4axis driver board
(works ok with other programs turbocnc k-cam etc)
all suggestion welcome
Re: new setup
« Reply #1 on: December 21, 2007, 02:13:51 AM »
Close Mach then browse to the Mach3 folder and double click on the DriverTest.exe to see if your driver is installed properly.
If it is and you pass the test then please attach your xml file and we can have a look and see if we find any problems. To attach your xml you will need to use the reply button then choose the additional options, you will also need to copy your xml to another loactaion on your computer and rename it or the forum will not allow you to attach it, something like mattdaniels.xml should work fine.
