Hello Guest it is November 19, 2026, 08:51:14 PM
Author Topic: SpindleRPM  (Read 14494 times)
SpindleRPM
« on: April 20, 2006, 09:59:56 PM »
How do I set up Mach3 to tell me what RPM my spindle is turning with a simple interupt signal? It only has one notch so it would be one round per pulse.
 I just do not know where to set up the signal.
Tommy C.
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
Re: SpindleRPM
« Reply #1 on: April 20, 2006, 10:45:25 PM »
I am just working on this same thing, I used a PDMX spindle sensor and wired the signal up to the A axis home limit switch input on a Bob Cambell breakout board. The spindle sensor requires 5 volts but the breakout board had a 12 volt power supply for this sensor so I used a couple of resistors soldered in the wire to reduce this down to 5 volts. Set up the input signal for index to pin 15 in the ports and pins, at least that's what the cambell board uses for this input.
