Hello Guest it is October 21, 2026, 12:57:06 AM
Author Topic: movement stops but dro says its still going  (Read 23890 times)
Re: movement stops but dro says its still going
« Reply #10 on: January 14, 2008, 12:13:34 PM »
i tried renaming it twice and it still says that i cant post that type of file
dave
« Reply #11 on: January 14, 2008, 01:16:56 PM »
Send me a PM and I will give you an email address you can send the xml to, I will then post it here.
Offline Bodini
  •  216 216
« Reply #12 on: January 14, 2008, 02:01:36 PM »
What about "rotational soft limits" in config? (never used it, just asking) Uncheck that box if its checked.
« Reply #13 on: January 17, 2008, 06:37:25 AM »
hi bodini,
i dint see a box marked as " rotational soft limits"  but i tried a few things in config/homing;/soft limits.  nothing worked.  where exactly did you see the rotational limits box?
thanks dave
Offline Bodini
  •  216 216
« Reply #14 on: January 17, 2008, 07:23:26 AM »
[pull down menu] Config --> General Config --> lower right side
I'm sure that thats not it, but if its as easy as unchecking a box, why not look.
