Hello Guest it is November 11, 2026, 11:00:34 AM
Author Topic: Uploading g codes  (Read 21493 times)
Re: Uploading g codes
« Reply #10 on: December 11, 2007, 08:31:52 AM »
Hey, have some other question, i want to conect the plasma, which pin do i have to use, i looked at the mach manual, there is no info about it.  input or output? and what to check in the enable or trig options or anywhere else? Im going to use a 5volt relay to trig the plasma torch, that is only for signal isnt it? I mean there will be no problem with that kind of relay?
 Luis
