Hello Guest it is November 23, 2026, 11:31:40 AM
Author Topic: Mach 3 plasma table DTHC issues  (Read 12 times)
« on: November 23, 2026, 10:33:42 AM »
I recently acquired a used arclight 12000 plasma table that runs Mach 3. I have been figuring out how to run it and understand it, but I am having issues with something I cannot figure out. When I make a G code with sheet cam and load the G code into Mach 3, it cuts the part fine and DTHC follows the G code commands. After the part is finished cutting, and I want to cut another part, The DTHC no longer follows the G code and the torch plunges into the material when I slow down for holes or corners. It does this whether I load a new G code, or try and use the same one. If i close Mach 3 and re load it, it will work fine until I finish cutting the first part, then I goes back to not following the G code. Its really frustrating when I need to cut multiple parts in a day I have to constantly close, open and load every time.
