Hello Guest it is October 28, 2026, 06:30:21 AM
Author Topic: Help Connection from PoKeys57E to PC?  (Read 15062 times)
« on: August 31, 2026, 12:40:45 PM »
Hello,
I want to control my lathe using Mach3 and a PoKeys57E board, running on Windows XP. The PoKeys unit is supposed to be connected directly to the PC. Unfortunately, I cannot establish a connection between the board and the PC. I am currently using a standard patch cable; could it be that a crossover cable is required for this connection?
Best regards,
Hans
  •  9,375 9,375
Re: Help Connection from PoKeys57E to PC?
« Reply #1 on: September 01, 2026, 12:38:55 AM »
You do not need a crossover cable.
You do need to check that .net framework 3.5 is installed and enabled for configuration of the 57e.
You need to set the correct IP address etc.
Hope this helps,
