Hello Guest it is October 30, 2026, 11:14:23 AM
Author Topic: Help needed with Mach 3 and spindle control  (Read 252917 times)
0 Members and 7 Guests are viewing this topic.
« on: August 04, 2026, 01:50:28 PM »
I have a Blue Elephant 1325 3 axis router and Mach 3 software. Connection to the XHC controller board in the cabinet is by USB cable and the installation came with the wrong (I assume older) version of the ncusbpod.dll plugin. I downloaded updated version from XHCs website, and now the Mach 3 software is talking to the machine, but I only really have control of the X,Y, and Z on the table. The spindle immediately spools up as soon as I open Mach 3...to what appears to be the minimum 6000 RPM (as set on the VFD) of the 6kW liquid cooled motor. I can change spindle speeds by typing, say "M3 S12000", but I can never stop the spindle. "M5" is completely ineffective. Only way to stop it is by closing Mach 3 or pushing "STOP / RESET" on the 7.5kW Fuling / Fulinn motor VFD.
I've tried getting help from various AI outlets but I get taken for a long loop that never goes anywhere or solves the problem. Is this a port / pins setting issue?
Any help would be greatly appreciated.
Re: Help needed with Mach 3 and spindle control
« Reply #1 on: September 07, 2026, 04:15:19 AM »
does the spindle stop correctly if you use the Mach3 on-screen spindle controls, rather than sending the M5 command? Also, which exact XHC controller model and Mach3 plugin/version are you using? That information might help narrow down whether this is a configuration or plugin issue.
« Reply #2 on: September 10, 2026, 05:16:33 AM »
I’d check the Mach3 spindle output and XHC plugin port/pin assignments first, because an incorrect spindle-enable or direction signal can cause the VFD to run immediately while leaving M5 ineffective.
« Reply #3 on: October 06, 2026, 02:28:00 AM »
Yes, this is primarily a combination of a spindle relay/output signal configuration mismatch in Mach3 and an inverted/floating 0–10V or PWM run-command state on the XHC USB board and the Fuling/Folinn VFD.
