Hello Guest it is September 27, 2026, 06:09:40 PM
Author Topic: mach2 and G76  (Read 33878 times)
Re: mach2 and G76
« Reply #10 on: April 18, 2006, 07:19:20 PM »
i will try tomorrow and thank you again
marcel beaudry
Re: mach2 and G76
« Reply #11 on: April 19, 2006, 04:05:18 PM »
dear sir
i can see the light at the end of the tunnel both the axes work as they should in manual and in program mode the only thing missing is the spindle turning even when i input a speed by hand the spindle does not turn thank you for your time
marcel beaudry
Re: mach2 and G76
« Reply #12 on: April 19, 2006, 08:27:21 PM »
That is odd.. It should be working..
www.newfangledsolutions.com
www.machsupport.com
Re: mach2 and G76
« Reply #13 on: April 19, 2006, 08:42:27 PM »
dear sir
is there some things i can check in the configuration
marcel beaudry
Re: mach2 and G76
« Reply #14 on: April 19, 2006, 08:51:21 PM »
I am going to look a bit more and see if I have done somthing wrong...
www.machsupport.com
Re: mach2 and G76
« Reply #15 on: April 21, 2006, 02:40:27 PM »
Dear Sir
i d'ont know if it has a bearing on my spindle not turning but when i go to diagnostic i have (output 2 flashing)
marcel beaudry
Re: mach2 and G76
« Reply #16 on: April 22, 2006, 06:58:21 AM »
Here is one more test... after that I would need to see your machine :( but if you are willing to try a few more XML's i think we can get it.
www.machsupport.com
Re: mach2 and G76
« Reply #17 on: April 22, 2006, 10:11:35 AM »
Dear Sir
i am willing to try anyting to make the lathe work . the last file worked on both axes but the spindle still will not turn and when i go to diagnostic now it is output 3 that flashes red
marcel beaudry
