Hello Guest it is October 25, 2026, 01:47:21 PM
Author Topic: Is This A Bug In Mach3 ver 2.60  (Read 32667 times)
Re: Is This A Bug In Mach3 ver 2.60
« Reply #10 on: November 26, 2007, 07:22:13 AM »
Hi N4NV
I am using a C11 from cnc4pc
It is an opto isolated board also my drivers are opto isolated  :'(
That is the problem, i am getting some sort of accumulated error.
So how do i fix it please.
Phil_H
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #11 on: November 26, 2007, 07:32:41 AM »
Hi:
 Its possible you have a direction prechange thats too low, did you try making the Direction wdth to 10 on the motor tuning screen? Some drivers need a delay that is a bit wide when changing directions.. Id try a few values, ( same test proceedure) and see if it varys the amount lost , or even corrects it..)
Art
« Reply #12 on: November 26, 2007, 07:48:07 AM »
Hi Art thanks for your help
I have them both set at 5 is there an upper limit ?
Tried them up to the limits 25 and 15.
The error has now gone from 0.255mm to 0.21mm but they are not losing but gaining ?
My test is from Zero to -60 after the 50 cycles Zero on my DTI is -.210mm now
Phil_H
« Last Edit: November 26, 2007, 08:42:12 AM by Phil_H »
« Reply #13 on: November 26, 2007, 08:38:04 AM »
Phil,
You  said :-
"It is an opto isolated board also my drivers are opto isolated"
Apparently this can cause problems but not always. It would be worth connecting your step and direction signals from the input of your BOB to your drivers,just to eliminate this as possible problem.
Ian
« Reply #14 on: November 26, 2007, 09:44:38 AM »
Could you please make a simple prgram to test with that has not Subs ? Please make a file that has a simple Z+ Z- and tell me if you have the same problem.
As a test have you tried the sherline mode under ports and pins?
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #15 on: November 26, 2007, 09:53:03 AM »
1) What motors are you using?
2) What is the native step resolution of the motors (steps per rev)?
3) What microstepping are you using on you controller?
« Reply #16 on: November 26, 2007, 11:38:17 AM »
Phil,
Have you made sure you have taken precautions to put noise under control?  Some earlier versions of the C11 board you are using could be affected by noise and cause that problem.  What is the revision number on the board?
Arturo Duncan
http://cnc4pc.com
« Reply #17 on: November 26, 2007, 12:10:22 PM »
Hi Brian
I run code as you said the result was an error of -0.2275 "From a consistent-.0.2555mm"
Then ran same code in Sherline mode now error is -0.2625mm
Hi Andrey
The motors are Astrosyn MY259RE
Y axis 400 steps per rev
Using 10 micro steps
Hi Arturo
All my wiring is tidy, signal wires are not close to power wires
The results are very consistent surely with noise i would be getting Inconsistent results.
The board revision is 3.1 if i remember correctly
How could i test for noise
Phil_H
« Reply #18 on: November 26, 2007, 12:20:13 PM »
Phil,
I would like to send a new Breakout Board so we can rule this out.  Please send a me a message with information of your inital order so I can locate it.
Arturo Duncan
« Reply #19 on: November 26, 2007, 12:35:32 PM »
Hi Arturo.
Thanks for the kind offer, it seems my email is playing up, i can receive but not send at the moment.
So will try later.
Phil_H
