Hello Guest it is October 23, 2026, 10:07:24 PM
Author Topic: X-Axis stutters when moving X &Y with Cursor-keys  (Read 30831 times)
Re: X-Axis stutters when moving X &Y with Cursor-keys
« Reply #10 on: April 18, 2006, 06:09:56 PM »
Here is the first test...
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: April 18, 2006, 08:36:28 PM »
Brian,
I took the file and loaded it. First thing I did was test as you configured it. Everything worked fine. Then, I turned off the OUTPUTS I configured on Pins 8 & 9 on Port 1 and tested again. Everything works as well.
I looked for changes you had made in the file, and noticed the 5 micro second entries in both Step and Direction, but did not notice other changes. Are there other you entries you made that I did not recognize??
Thanks for your time and attention. I appreciate it!!
David
« Reply #12 on: April 19, 2006, 07:07:37 AM »
You Got me :) That is all I did... Other than the fact that I looked for any odd settings.
So you are good to go now?
www.machsupport.com
