Hello Guest it is November 13, 2026, 07:32:44 PM
Author Topic: Canned Drilling Cycle Problem  (Read 12425 times)
« on: November 22, 2007, 09:45:52 AM »
Hi all.
Why does using the drilling canned cycles change constant velocity to exact stop. >:(
Is it possible to keep constant velocity when using drilling canned cycles
The Code i am using "G99 G83 Z-10. R-5.6 Q2. F15."
Phil_H
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Canned Drilling Cycle Problem
« Reply #1 on: November 22, 2007, 10:50:13 AM »
I think its the G80 that kills all modal commands, I asked Art about changing this some time back, so everything went back to how it was before the cycle call, but it sounded is if that may be a major job.  Maybe in Quantum.
Graham.
« Reply #2 on: November 22, 2007, 11:58:45 AM »
Hi Graham thanks for the reply. That is bad news. Come on Art forget Quantum, fix Mach. ;D
As i lose position every time i run the part, i will do a subroutine for the Z axis.
But i am unsure of the correct syntax for subroutines i have searched the forum and found none, i have only seen the examples in the PDF manual.
Do you have an example to hand ?
The machine works fine except in exact stop mode
Phil_H
  •  2,785 2,785
« Reply #3 on: November 22, 2007, 12:08:53 PM »
you can do it like this:-
G20 G40 ETC.
G00 X0 Y0
M98 P1
G00 X1. Y1.
M98 P1
ETC.
M30
O1(SUB)
G00 Z-5.6
G01 Z-8.6 F15
G00Z1.
Z-8.
G01 Z-10.
G00Z1.
M99
Graham.
« Reply #4 on: November 22, 2007, 12:56:29 PM »
Thanks Graham
Phil_H
