Hello Guest it is November 25, 2026, 12:01:36 AM
Author Topic: Mach3 Turn bug with rewind and tool table  (Read 6750 times)
« on: March 28, 2025, 06:00:42 PM »
Hello,
I’ve discovered a bug in version.062. When I run a program and after it is finished, if it rewinds or if I click rewind, it corrupts the X and Z dro by adding the correct location and the offset in the tool table for that tool. It adds them together and places that value in the dro.
If I go to the tooltable and open the tool table and click OK, the correct value is instantly back in the X and Z dro.
This happens regardless of screenset.
If I use tool 1 which has no offset values in the tool table it doesn’t happen. If I use any other tool with x and z offsets, it happens when the program rewinds.
If I edit the program so there is no M30 the program completes but if I click rewind it corrupts the dro.
Would version.066 work better? Does the threading work with a parallel port on .066?
Thanks for any advice.
Mike
