Hello Guest it is November 10, 2026, 01:38:57 AM
Author Topic: please help for modbus in macro  (Read 178241 times)
« on: March 10, 2025, 02:55:23 PM »
hi
how to use write button in macro?
i can send hex value with this screen. but i can not send value in macro. please help me. :( :( :( :( :( :( :(
- Attachments and other options
Re: please help for modbus in macro
« Reply #1 on: March 10, 2025, 03:00:09 PM »
also by modbus poll software its works fine.
« Reply #2 on: March 10, 2025, 05:07:29 PM »
Have a look at this article I wrote.
https://www.homanndesigns.com/pdfs/Using_Modbus_with_Mach3.pdf
Peter.
Homann Designs
http://www.homanndesigns.com
« Reply #3 on: March 11, 2025, 01:35:17 AM »
hello peter
I hope you well.
thanks for help.
I do your guidance pdf.
when test window is same attached picture the write button work fine. but its dont work.
the io bord have 8 out put. get a integer value from 1 to 256. value 4 means 3th output. value 5 means output1+output3.
« Reply #4 on: March 11, 2025, 01:37:16 AM »
dear mr peter
why we can not use a simple code in macro such as: sendmodbus(coil,adress, . ., value)
whit out brain.
« Reply #5 on: March 11, 2025, 01:50:51 AM »
I want just send integer value 0 to 255 can you tell me whats is correct  for this picture (modbus configuration window)?
the io bord work fine with test window (modbus serial control manitor window)
« Reply #6 on: March 11, 2025, 01:53:51 AM »
I want use this io bord
« Reply #7 on: March 11, 2025, 02:13:30 AM »
when I use sendserial("test") in macro. mach3 can send data to serial port. but it can just send string not hex.
if I can send hex (01 06 00 01 00 04 D9 C9) its means value 4 in modbus and the output 3 is actived.
can you help me to send hex to serial port?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #8 on: March 12, 2025, 11:56:00 AM »
Have you tried it this way :-
sendserial("test" & Chr(D9))
« Reply #9 on: March 13, 2025, 06:53:21 AM »
dear Graham Waterworth
thanks for comment. chr(D9) do not add any think to serial port .
