Hello Guest it is November 19, 2026, 02:54:21 AM
Author Topic: Gcode misundestand for ATC and Tool heigh  (Read 96955 times)
« on: February 07, 2025, 06:59:31 AM »
Hi and thanks for your help.
I have some problems to understand why sometimes i cant put to zero correctly and i need to reboot all for start.
I doesn't understand correctly the tool height gcodes and ATC M106 tool changes/operations.
I have all tool heights sets in tables (i have one macro for measure all tools and work good).
Anyone can tell me the correct G i need to stay for set to 0 the tool with atc manually, some questions are:
I need to stay with tool g43 enabled when zero with a tool
If i change manually i put m106 t1 only i need to specify H1? (sorry im very lost, because this problem only occur some times and all is when i change manually tools or after use a gcode i think).
g53 or g54
One example of my Gcode i use and work correctly (but maybe this affect when i change 0).
--------------------------------------------- Head of the gcode -----------------
(Material Size) (X=210.000, Y=500.000, Z=34.000)
G00 G017 G21 G40 G49 G80 G90 G91.1 G71
M6 T9
(Tool Number:9) ( 4.3 grados cónica con 0.500 mm de rad. de pta.)
G43 H9 G0Z55.0000
M03M7 S18000
G0 X109.6005 Y0.0442 Z55.0000
  Z45.3583
------------------------finish-----------------------------------------
G0 X0.0000 Y0.0000
G0Z55.0000
G0X0.0000Y0.0000
M09
M30
Thanks if anyone have experience and give me some tips.
