Hello Guest it is October 18, 2026, 04:00:42 PM
Author Topic: Mach3 relay control  (Read 6422 times)
Mach3 relay control
« on: February 04, 2025, 05:59:56 AM »
Hello,
Mach3 MK4-V control in version 5.8, I want to connect the coolant control to OUTPUT3 - I use the built-in button. The configuration in Port&Pins is probably correct - after starting the milling machine OUTPUT3 (connected and configured to Port 1 Pin 2) in the diagnostics section the diode does not light up - there is no voltage between OUTPUT3 and 24V Power OUT, after starting OUTPUT3 the diode in diagnostics lights up, there is voltage between OUTPUT3 and 24V Power OUT - the relay works - the problem occurs when I want to turn off the relay, the diode at OUTPUT3 goes out, but the voltage is still there. Where could the problem be?
Relay connections - OUTPUT3 to -, 24V Power OUT to +
