Hello Guest it is November 19, 2026, 03:32:55 AM
Author Topic: New machine Gcode stops on third line  (Read 106239 times)
Re: New machine Gcode stops on third line
« Reply #10 on: December 03, 2024, 11:22:27 AM »
When I start Mach the reset is active like always. when I click it I get "limitswitch triggered" I click reset again it goes away.
Do these setting look good?
« Reply #11 on: December 03, 2024, 04:31:46 PM »
What does this mean? and why do I get errors trying to post files to this stie?
  •  9,378 9,378
« Reply #12 on: December 04, 2024, 12:08:18 AM »
The Configuration Check Facility points out any errors in Pin allocations.
You need to check your Ports & Pins allocations as they are obviously incorrect.
For example you have Port 1 Pins 2 & 3 set as inputs - you can only use Pins 10-13 & 15 for inputs.
When posting files to the forum they need to have a unique name that has not been used before (its a quirk).
« Reply #13 on: December 04, 2024, 08:20:04 AM »
Here is where im at now. I got the limits sorted out. but still hangs up on 5th line of code
