Hello Guest it is November 02, 2026, 10:05:41 PM
Author Topic: Mach4 dual axis for z and a axis swap.  (Read 96305 times)
« on: October 01, 2024, 04:10:04 PM »
m831.mcs is the change axis from z to a. m832.mcs is the reset of axis z and a back. The g-code example is also included. Placement of the *.mcs files should be under profile then under macros. m831 resets all motors for both z and a. So if you're using slaves... not a good idea.
Re: Mach4 dual axis for z and a axis swap.
« Reply #1 on: October 06, 2024, 01:41:55 PM »
It appears that I have failed to load the files from the last post. Sorry so here they are...
