Hello Guest it is November 22, 2026, 07:27:53 AM
Author Topic: Mach 4 V2 How's it different?  (Read 25433 times)
  •  9,378 9,378
Re: Mach 4 V2 How's it different?
« Reply #10 on: August 18, 2024, 01:44:14 AM »
I am running the Contour. I am also running a SmoothStepper. Will a version upgarde solve the problem with the Contour and will it also opearte with the SmoothStepper? Thank you for the reply!
My guess is that a version update will make no difference but you would have to 'try it and see' to be sure.
« Reply #11 on: August 18, 2024, 08:28:47 AM »
The update was painless and it appears to have solved the problem. Thank you for the replies!
  •  9,378 9,378
« Reply #12 on: August 19, 2024, 12:20:35 AM »
Excellent news, I am pleased that you have solved the problem.
