Hello Guest it is November 13, 2026, 08:05:30 PM
Author Topic: Video Card  (Read 29083 times)
Re: Video Card
« Reply #10 on: November 25, 2007, 02:10:58 PM »
I'll be out for a while, but if you will post your gcode file as an attachment maybe someone can load it and compare.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Video Card
« Reply #11 on: November 25, 2007, 02:15:40 PM »
Hi, Ron
Theres a way in Lathe to Fix this sort of Arc problem, Looking in Mill now, Haven't found it yet though.
Thanks, Chip
Your file loads fine hear for me, It's a I,J issue in Arc's, What Post processor are you using.
« Last Edit: November 25, 2007, 02:41:59 PM by afn09556 »
Re: Video Card
« Reply #12 on: November 25, 2007, 02:18:04 PM »
Here is the gcode.
Ron
Re: Video Card
« Reply #13 on: November 25, 2007, 03:37:53 PM »
Go to the Config menu then General Config and change the IJ Mode to Inc, that should cure your problem.
Offline Chip
  •  2,055 2,055
Re: Video Card
« Reply #14 on: November 25, 2007, 03:47:31 PM »
Hi, Hood
It was right in my face D---u-h---!!
What's the G-code for setting "Jog mode" for "Cont", "Step" Mode while your at it, More------Brain------------- Fade
Thanks Chip
« Last Edit: November 25, 2007, 03:52:14 PM by afn09556 »
Re: Video Card
« Reply #15 on: November 25, 2007, 03:52:16 PM »
That worked. How about "Motion Mode" should that also be "Inc"?
Thanks alot. Ive had this problem for weeks & I was going crazy.
Ron
Re: Video Card
« Reply #16 on: November 25, 2007, 03:57:08 PM »
Last post should be "Distance Mode"
Ron
Re: Video Card
« Reply #17 on: November 25, 2007, 03:59:06 PM »
I think it will depend on your code but I would think Distance mode would be Absolute.
Re: Video Card
« Reply #18 on: November 25, 2007, 04:04:16 PM »
Thank you guys very much.
I cant tell you how this drives a person crazy.
Dont know how it got checked Absolute. I loaded Mach3 on the laptop & it was checked Inc.
Thanks again
Ron
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Video Card
« Reply #19 on: November 27, 2007, 10:12:42 AM »
Hey,
Was gone for ThanksGiving weekend, just  got a new computer after 5 years...my P4 3.0 kicked the bucket
I found it on ebay:
-Intel Core 2 Extreme QX6700 Quad Core (4 processors!!!  :o)
-Asus Striker Extreme LGA 775 SLI ATX Motherboard
-EVGA NVIDIA GeForce 8800 GTS Video Card (Swich this out for a Nvidia Quadro 1400 PCI-E 16X)
-Two 750GB (1.5TB) SATA II Hard Drives (Raid 0)
-4GB PC2-6400 DDR2 RAM
-Dual 20X DVD Burner
I can OverClock @  3.744 GHZ  for each of the cores at a 3663 FSB :O...my feet are getting alittle warm thou :)
(Haven't OC it thou)
...like running a Core 2 Due @ 14.976 GHZ
I would not suggest the Asus Striker motherboard...unless you have alot of time to set things up on it..without breaking it.
Great for 3d modeling CAD/CAM work, but since everything is so new alot of Driver and software updates every month.
I would suggest running this computer in 64bit to take advantage of the 4gb ram...
I'm using a AMD64 3800 with 1gb RAM and Nvida Quadro 1400 PCI-e 16X to run Mach on my machine.
« Last Edit: November 27, 2007, 10:16:59 AM by zealous »
