Hello Guest it is November 13, 2026, 10:01:19 AM
Author Topic: Art or Brain PLEASE have a look  (Read 11725 times)
Offline klmark
  •  107 107
« on: November 17, 2007, 03:58:15 PM »
Hi Guys
As I have posted before on this problem I don't know maybe I am the problem Attach are to file One is LC cam toolpath  JPG file all looks good in LC as you will see on the file if I post it to mach 3 I get those z axis moves that should not be there as you will see they show up in the Tool path JGP file
   Would Please let me someone know what I am doing wrong or if there is a problem in the software  Don't get me wrong I like the software and I appreciate the hard work that it had to take to get there
        Klmark
« Last Edit: November 17, 2007, 04:23:50 PM by klmark »
Offline docltf
  •  354 354
Re: Art or Brain PLEASE have a look
« Reply #1 on: November 17, 2007, 11:10:35 PM »
klmark
lcam will look at a move like this.
g00 z.200   as a rapid move - showing a broken line
g01 z.200   as a chain - showing a solid line
when you take a drawing with no z moves,then add z depth of cut with a feedrate then  generate g-code with lcam.
then import it back into lcam you will see the z travel as a chan.
Offline klmark
  •  107 107
« Reply #2 on: November 19, 2007, 08:32:32 AM »
Yes but how do I get rid of them ? A guy can do it manual but if you want to do a part in a hurry it is no fun
   klmark
Offline klmark
  •  107 107
« Reply #3 on: November 20, 2007, 08:29:46 AM »
Hi Guys
Am I the only guy with that problem so no one can tell me what I do wrong It can,t be that I am the only guy using Lcam because it is a nice and simply program to us I run every file through Lcam to get my G code file
                                       Thank you        klmark
