Hello Guest it is November 03, 2026, 08:17:35 PM
Author Topic: Rotary Setup on a new machine  (Read 359115 times)
Re: Rotary Setup on a new machine
« Reply #20 on: July 29, 2024, 06:42:47 PM »
0,0 for x and y
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #21 on: July 30, 2024, 06:31:03 PM »
It is on the right hand side Toolpath Material Setup tab on my version.
« Reply #22 on: August 01, 2024, 12:23:20 AM »
So I can now do move the start point. Here are the lesson I learned.
First, the Wrapping vector has to be ungrouped. I guess when the wrapping gadget creates the vector and you then create the toolpath it groups the vector and the object it is projected on.
Secondly, You have to be in 2D View. While you can select the vector in 3D View with the node editor, it will not let you move the start point. Once you are in the 2D View it will allow you to relocate the start point.
Thanks for all the feed back. Stay tuned for some neat stuff I hope to post this weekend.
