Hello
Guest
it is
October 25, 2026, 12:41:09 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
how connect a spindle encoder to a Mach3 White Eagle board (red version) ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: how connect a spindle encoder to a Mach3 White Eagle board (red version) ? (Read 13090 times)
p7m13
18
on:
June 14, 2024, 07:56:15 AM »
I search the connections of a spindle encoder and find nothing. Thanks for your help
JohnHaine
975
Re: how connect a spindle encoder to a Mach3 White Eagle board (red version) ?
Reply #1 on:
June 14, 2024, 10:50:19 AM »
Please post a link to the board details then someone might be able to help.
p7m13
18
how connect a spindle encoder to a Mach3 White Eagle board ?
Reply #2 on:
June 14, 2024, 01:54:03 PM »
https://buildyourcnc.com/item/electronicsAndMotors-electronic-component-breakout-Mach3-USB-Board
JohnHaine
975
Reply #3 on:
June 14, 2024, 02:04:43 PM »
Well if you look at the FAQ you will find this:
This controller does not have an encoder input to determine the speed of a lathe spindle. The Pokeys57CNC does have an available encoder input.
https://www.buildyourcnc.com/item/electronicsAndMotors-electronic-component-breakout-Mach4-mach3-USB-ethernet-Board
Click the link to add information to this solution:
[575] how do i connect a lathe spindle speed encoder to this usb breakout board controller so i can set up for thread cutting on my lathe and on the mill for threading
The board does support spindle speed control but clearly not closed loop since you cannot connect either an index pulse or encoder.
Last Edit: June 14, 2024, 02:06:30 PM by JohnHaine
Print
Pages:
1
Go Up
« previous
next »
