Hello Guest it is October 26, 2026, 04:24:54 AM
Author Topic: Mach3 Turn X axis problem  (Read 29897 times)
Re: Mach3 Turn X axis problem
« Reply #10 on: May 30, 2024, 08:18:47 AM »
To Graham,
Thanks for your detailed workflow, I will review mine for what I might be missing. Do you have any X offsets for your Master tool?
I noticed yesterday that when I tried to use the Tool Table screen, it would not post the offsets, I wonder if that's related.
Jim
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: May 30, 2024, 05:30:52 PM »
Every tool has an X & Z offset.
« Reply #12 on: May 31, 2024, 02:43:01 AM »
To Graham,
Jim
You need to click apply after entering the offset and return
« Reply #13 on: June 03, 2024, 07:56:03 AM »
To John and Graham:
Thanks for taking your time to give suggestions to fix the problem I was experiencing. I dove into it over this past weekend and discovered my own stupidity. When I calibrated my axes, I used the software to move them and compare the commanded move vs actual movement. What I failed to observe was that I was in Diameter Mode instead of Radius Mode.
I offer that machine calibration should always be done in Machine Coordinates and Radius Mode in order to not do what I did!
Jim
« Reply #14 on: June 03, 2024, 09:59:55 AM »
Glad to help and that you have fixed it.  I use exactly the technique you describe.
