Hello Guest it is October 25, 2026, 02:15:08 PM
Author Topic: 2 axis lineborine machine  (Read 12149 times)
« on: May 01, 2024, 04:02:17 PM »
Hello.
I'm using Mach3 to control a lineboring machine.
The machine is 2 axis:
1 is a stepper motor (Nema 34) for axis X, The other is a 130 servomotor for axis Y.
I don't need to run any Gcode in this machine, i basically only need to jog the motors and run the in "velocity mode" where i choose the speed very specifically.
but i need something tricky, I need to move axis X coordinated with axis Y, so that i choose the velocity of each motor independently.
I know probably mach3 isn't the most straightforward option for this, but can it be done?
Also, the Y axis will either run very fast or extremely slow, at controlled speed, but
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: 2 axis lineborine machine
« Reply #1 on: May 02, 2024, 10:25:10 AM »
All axis in Mach are blended together at the selected feed rate so you need something like an Arduino with custom code to do what you need.
« Reply #2 on: May 02, 2024, 01:10:10 PM »
Surely you just need to set a feed rate which is the root sum of squares of the two velocities?
