Mach Discussion > Mach4 General Discussion
input to stop machine
(1/1)
Bill_O:
We have a new machine and I am going to be putting a pressure sensor on so if the air pressure gets too low the machine will stop.
What would be the best place to put the code?
PLC Script?
Signal Script?
Any other place?
Open to any ideas.
Bill
Graham Waterworth:
Why not just wire it through the e-stop circuit.
Bill_O:
Graham,
Perfect.
MN300:
If the air pressure drops slowly enough a pressure switch could signal the impending problem with enough time to stop the machine with the feed hold. This would allow you to continue once pressure is reestablished.
Navigation
[0] Message Index
Go to full version
