Hello Guest it is October 26, 2026, 04:22:03 AM
Author Topic: Command to disable only one function or device in modbus?  (Read 13359 times)
« on: March 01, 2024, 08:26:58 AM »
Hi everyone,
I'm looking for either a register or a command to start/stop specific modbus functions and/or devices.  (similar to right-clicking on the device or function in the Modbus Diagnostics window).  I'm trying to limit overhead and only use the toolchanger modbus when needed so I can turn off the toolchanger between changes.
I was able to find the command register to enable/disable ALL of the modbus at once: mbcntl/command but I was hoping for more granularity
I'm also able to find the status of each device/function but they appear to be readback only and not commands (for example MB2-6052/function0/rc )
Thanks!
Re: Command to disable only one function or device in modbus?
« Reply #1 on: June 09, 2024, 12:13:35 AM »
just set a coil to turn it on or off and use a global in the PLC.
many ways you can do this, input_sig comes to mind
« Reply #2 on: July 04, 2024, 03:12:56 PM »
Could you explain a bit more? Sounds like the solution to me
