Hello Guest it is November 19, 2026, 03:32:46 AM
Author Topic: Mach4 Lathe weird toolpath  (Read 49357 times)
« on: January 31, 2024, 11:26:25 AM »
Hi all,
I'm trying to figure out the different Gcode command on a retrofitted EmcoTurn120. I'm trying to cut an internal profile as shown in the picture below. I wrote the Gcode below but I get very strange toolpaths when i run this on the lathe. It refuses to cut the arc's as I've designed them. It just takes of in the complete other direction. I've tried altering the G2/G3 commands, and changed the setting on the machine to absolute mode but I still can't get the proper toolpath. Any help on this problem is greatly appreciated!!
Thanks!
Gcode:
(Program start)
N00   G00 G54 G18 G40 G80 G98 G21 G91.1
N10   G50 S3000
N20   G97 S1600 M3 M08
N30 (Cut profile)
N40   G01   X13.80            F80
N50   G01   Z-2.36
N60   G03   X13.62   Z-2.61   I13.0   K-2.36
N70   G01   X13.40   Z-2.75
N80   G02   X13.40   Z-3.25   I14.02   K-3.0
N90   G01   X13.62   Z-3.39
N100   G03   X13.80   Z-3.64   I13.0   K-3.64
N110   G01   Z-9.3
N120   G03   X13.48   Z-9.62   I13.0   K-9.3
N130   G01   X13.32   Z-9.68
N140   G02   X13.32   Z-10.32   I14.02   K-10.0
N150   G01   X13.48   Z-10.38
N160   G03   X13.8   Z-10.70   I13.0   K-10.7
N170   G01   Z-15.0
N180   G01   X11.0
N130   G00   Z1.0 M09
N140 (Program end)
N150   G00   G53 X-2.0   Z-2.0
N160   M30
N170   %
Offline TPS
  •  2,627 2,627
Re: Mach4 Lathe weird toolpath
« Reply #1 on: February 01, 2024, 10:11:18 AM »
somewhere in cofigation general you can switch IJ Mode absulute and incremental
