Hello Guest it is November 13, 2026, 06:15:55 PM
Author Topic: Execute Button Script with button configured screen designer  (Read 56296 times)
Offline TPS
  •  2,627 2,627
Re: Execute Button Script with button configured screen designer
« Reply #20 on: January 27, 2024, 09:48:29 AM »
so it looks like UserLed(1500) is false if you push the buttom
in this case If condition should look like this:
Code: [Select]
If ((GetUserLed(1500) = False) And (GetUserLed(1501) = True))  Then
« Reply #21 on: January 27, 2024, 01:17:56 PM »
I tried but if I put true
the button doesn't work...
I have to put false
And (GetUserLed(1501) = False))  Then
otherwise it doesn't work, I don't know why...
If I leave it false, is it a problem could I have malfunctions?
« Reply #22 on: January 27, 2024, 04:25:08 PM »
I tried to implement the button from the panel by adding to the code in macropump as you wrote
 Or (GetUserLed(1503) = True) Then
and I modified the button script as per the attached image (imm-f)
I tried but failed to invoke GetUserLed(1503)...
I press the button on the panel but nothing happens...
am I doing something wrong?
Offline TPS
  •  2,627 2,627
« Reply #23 on: January 28, 2024, 03:16:56 AM »
for test place three simple Led's on your screen (1500,1501,1503)
to see the status of those three led's.
then you can witch is true or false.
« Reply #24 on: January 28, 2024, 04:52:58 PM »
hi TPS I did the tests with the LEDs.
And they worked in the panel.
At this point, however, I was unable to recall UserLed1503..
I tried to replace the code in macropump using the codes 1 and 0 (Imm-g) instead of the booleans true and false.
It worked great.
The cycle start panel button works!!! calls the script contained in macropump.
And the external button with userled1500-1501 from external button from brain also works. At this point I changed the brain to pass signal (imm-b1).
Great job, thanks again for your help, you were very kind, I couldn't have done it without you.
