Hello Guest it is October 11, 2026, 08:20:19 PM
Author Topic: Surface Mapping  (Read 13624 times)
Surface Mapping
« on: November 21, 2023, 01:06:24 AM »
Hello,regards
i am using this forum for the first time,  have a problem with setting up the pmdx411 to mach4 windows 10,  set up wizard to do surface mapping and unit starts to do mapping and start is ok does the first z ok as soon as the second  z is read the machine stops and says ready.  do i need a plug in for the mach4 to do surface mapping?.
Thank you
Noel
Re: Surface Mapping
« Reply #1 on: November 27, 2023, 10:38:28 PM »
Update your mach4 software to the latest version, which may have fixed some bugs and improved the performance of the surface mapping wizard.
