Hello Guest it is October 25, 2026, 08:14:05 PM
Author Topic: Hole milling problem  (Read 23312 times)
« on: November 01, 2023, 04:22:50 AM »
Hi, I'm new to the forum and would like to help with the problem.
I use Mach3 software.
The problem is when I make a hole in the milling material, diameter 18 mm. The router makes a 21.5 mm hole. Is there any scaling in the Mach3 program that affects it. If so, how to remove it
Re: Hole milling problem
« Reply #1 on: November 01, 2023, 03:57:10 PM »
Could you post your code? What size cutter are you using? Spiral mill or pocket?
