Hello Guest it is October 15, 2026, 10:25:44 AM
Author Topic: Turret lathe axis question  (Read 15742 times)
Re: Turret lathe axis question
« Reply #10 on: October 19, 2023, 05:16:32 PM »
Here is a picture
« Reply #11 on: October 19, 2023, 06:04:27 PM »
Are you running Mach4? If so it appears that the tool table edit function allows a built in Y axis offset field to be added, and I assume that the trajectory planner would actually use that offset. Could this work if you redefined your turret feed motor to be the Y axis?
Steve Stallings
www.PMDX.com
« Reply #12 on: October 19, 2023, 06:07:49 PM »
Interesting, I never thought about that. I’ll try it when I get a chance. Thanks Steve I think that will work.
