Hello Guest it is October 30, 2026, 07:23:43 AM
Author Topic: Nema 34 and CNC Router Problem  (Read 99309 times)
« on: September 27, 2023, 01:27:41 AM »
Hello everyone,
I have DM556T drivers(https://www.oyostepper.com/goods-112-Digital-Stepper-Driver-18-56A-20-50VDC-for-Nema-23-24-34-Stepper-Motor.html)
and I would like to get NEMA 34 series motors for them. I have these two in mind and I'm not sure if I could go with the stronger one considering the drivers.
https://www.oyostepper.com/goods-102-Keyway-Dual-Shaft-Nema-34-Stepper-Motor-707Nm-1001ozin-86x86x98mm-4-Wires.html
https://www.oyostepper.com/goods-510-E-Series-Nema-34-Stepper-Motor-Bipolar-18deg-120-Nm-169968ozin-60A-86x86x1515mm-4-Wires.html
Or do you think that even the weaker one is on the edge and I should go even lower?
Controlled from PC via LPT port. It will be powered by a 36VDC switching power supply. Designed to drive the axes of a CNC router with a floor plan of 0.7 x 1.2 m (2x Y-axis, 1x X-axis, 1x Z-axis), ball screws with a pitch of 5 mm. Wood "alloys" will be machined.
Or do you think that NEMA 34 are unnecessarily oversized for such a machine and NEMA 24 or 23 would suffice?
Thanks everyone in advance for the constructive comments!
As long as you have strong willpower, you will naturally have ability, cleverness and knowledge.
