General CNC Chat > Building or Buying a Wood routing table.. Beginnners guide..
Industrial Machine CNC Help
(1/3) > >>
RickyBobby8675309:
Hello,
I have recently got into CNC machines and want some help/suggestions for what I think is called a Break Out Board. I have an Industrial Machine CNC machine 4x8 and want to fix or update the machine. Earlier this year I had the machine working with the factory UC100 controller and breakout board. Unforchanetly shortly after the machine was up and running the UC100 parallel port controller was ripped out of the machine and someone else tried to install a cheap BOB from Amazon but did not succeed(cut wires). I am in the process of either repairing the machine to the original configuration or updating it to a USB or Ethernet BOB that works for Mach 3.
My questions are_
-Does anyone have pictures or diagrams of an Industrial Machine CNC cabinet wired up, mainly the Spindle controls, E stop, and inverter button
-Does anyone have recommendations for a BOB that would be an easy replacement for the original BOB that runs on Mach 3
I would appreciate any help
Jeremy
Graham Waterworth:
Hi Jeremy,
its better if you do it the other way around, post some pictures of the machine, control cabinet showing the installed parts and then we can see what you will need.  In most cases its not a big problem if its already been on a known controller.
Where are you based?
RickyBobby8675309:
Located in Lubbock, Tx. I will take photos tomorrow and post them.
RickyBobby8675309:
Here are some images of the machine
RickyBobby8675309:
Here are the rest of the pictures I have.
The CNC machine is used in a custom car audio shop for Subwoofer boxes and templates related to car audio.
Navigation
[0] Message Index
[#] Next page
Go to full version
