Hello Guest it is October 25, 2026, 03:09:49 PM
Author Topic: New/old DIY CNC upgrade?  (Read 27307 times)
Re: New/old DIY CNC upgrade?
« Reply #10 on: June 26, 2023, 03:35:52 PM »
Ok, the laser is this.
https://neje.shop/products/e30130
I was trying different connections and i tried connecting to pins 17 and 1. And it somehow worked..
I am attaching the manual of the BoB.
I dont know if i did something stupid or not. But for now it works. Although i would like to know HOW it works...
Also, because no local sellers have the smoothstepper, this board is all i've got so mach3 it is for now...
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: June 29, 2023, 04:14:15 PM »
To get PWM you connect to pin 1 and GND then set pulley speed 1  from 0 to 100 then calling S50 M3 will give you 50% power.
Its a while since I did this so maybe one of the others can put more light on this.
« Reply #12 on: April 09, 2024, 05:24:06 AM »
Just to confirm that you need a 5V supply to that BoB to make it work if you don't have a USB connection to it (which is only for power) and also a 12V supply if you want the 0 - 10V to work.
