Hello Guest it is October 11, 2026, 08:08:53 PM
Author Topic: Persistent value 163 after homed axis A  (Read 26119 times)
« on: May 11, 2023, 08:06:22 PM »
Hi guys!
I'm a problem in my machine running in Mach4 and CSMIO-IP/A plugin.
My machine have 3 axis: X, Y and C1 (C1 = A configured in tangential mode rollup X).
Wen i do a REF all Axis,  The DRO X and Y  comes to zero! OK!
But the C1 Axis DRO after homing procedure shows 163 !
The CSMIO plugin is set to 0 in the option "Move axis after home" or "Ofset after Home"!
On page Homing and Limits in Mach4 also.
Can anyone help me?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Persistent value 163 after homed axis A
« Reply #1 on: May 12, 2023, 11:24:21 AM »
Do you have an absolute encoder fitted to the axis?
What is the machine DRO value of the axis?
Do you have any values in the fixture offsets for that axis?
Is there a homing offset set for the axis?
« Reply #2 on: May 12, 2023, 11:37:09 AM »
Hi!
No absolute encoder.
The DRO value is actual position.
Fixture position no for the A axis.
Home offset =0
Thanks in advance!
