Hello Guest it is November 10, 2026, 04:22:11 PM
Author Topic: CNC Cutoff saw using Mach  (Read 40807 times)
Offline ardor
  •  130 130
Re: CNC Cutoff saw using Mach
« Reply #10 on: November 12, 2007, 03:26:42 PM »
If you need better accuracy, you might set up a retractable stock stop.
I cut to +/- 0.002
ardor
There is no approved dental use for WD40
« Reply #11 on: November 13, 2007, 01:19:05 PM »
Posted by: ardor
Insert Quote
Ardor,
Do you have a feeder or just manually feeding the stock & clamping with +-.002 accuracy?
Cutmore
Offline ardor
  •  130 130
« Reply #12 on: November 13, 2007, 04:10:11 PM »
Ardor,
Cutmore
Here's what it look likey.
Chain driven rollers feed the stock.
Stock hits the stop,turns stock feed off, &  triggers downfeed.
Down to limit, up we go.
Up to limit, stock feed starts.
Etc. etc.
(Heavy duty mounting for adjustable stock stop)
ardor
« Last Edit: November 13, 2007, 04:17:23 PM by ardor »
« Reply #13 on: November 14, 2007, 06:22:00 AM »
Ardor,
Thanks for the pictures,
I had thought about using a switch as a feed stop originally. The feeder is along the lines I was originally thinking too but after using my set-up the other day I am going to make a belted conveyor so I can cut down to to as short as possible. My main reason for making the feeder is that i cut hundreds of 1/2" long parts at a time and the material is 16-20 bucks a foot.
What brand is the saw you have? That does not look like a home brew feeder, but if it is you made a heck of a beefy set-up!
Cutmore
Offline ardor
  •  130 130
« Reply #14 on: November 14, 2007, 01:02:14 PM »
The brand is Pehaka.  German made.  I've had it for 30+ years.  Got is used.  Still cuts like the day I made the 1st cut.  So far I've had to replace one relay.  It has had some pretty heavy use, running production 24/7 months on end.  Every now and then I check to see if I could get parts, they are still making these battleships.   Damn.
ardor
« Reply #15 on: November 21, 2007, 05:49:37 AM »
Ardor,
I used my set-up last weekend with a new prototype feeder and a hard stop. I cut 126 pcs. without having to touch the saw! All these were within .003" of each other.
Here is a picture of my prototype including clamps!
cutmore
« Reply #16 on: November 21, 2007, 06:01:40 AM »
 :) Nice.
« Reply #17 on: November 21, 2007, 06:24:39 AM »
Brett,
Thanks, Wait till I get the real feeder done.
I need to increase the blade speed as I cut tons of plastic parts. So I may try a VFD to a 3phase on the saw.
So many ideas, so little time!
And to think, I bought this saw for $80 used. Added a $25 cnc4pc c10 breakout board, 2 stepper motors and drives, a 650mhz laptop($25) Some time, and Voilla!
What could be more fun?
cutmore
« Reply #18 on: November 21, 2007, 03:34:37 PM »
Cutmore,
Nice work.  BTW, what are you making with these ?
Joel
Offline ardor
  •  130 130
« Reply #19 on: November 21, 2007, 03:44:46 PM »
CUTMORE
Nice, you get 3 attaboy's.
Just remember, it takes 10 attaboy's to undo one Ooooohh sh**t.
ardor ;D
