Hello Guest it is October 23, 2026, 12:08:27 AM
Author Topic: access denied - Machine.ini  (Read 13451 times)
Re: access denied - Machine.ini
« Reply #10 on: May 01, 2023, 08:44:14 PM »
Craig,
I totally agree with you. I went through something similar with Mach3, then never needed to go back to the editor for years. Almost forgot how the internal code worked. I’m expecting a similar path with Mach4. It’s just the frustration climbing up the learning curve, which I feel could have been helped with improved documentation along with a slightly more robust error handling.
I think I’m seeing light with my coding, so hopefully it’ll be water under the bridge soon
Peter
