Hello
Guest
it is
November 13, 2026, 12:21:40 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 is tool z lifts when running code. Tool does not touch work.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Mach3 is tool z lifts when running code. Tool does not touch work. (Read 48407 times)
leaddennis
9
Re: Mach3 is tool z lifts when running code. Tool does not touch work.
Reply #10 on:
April 03, 2023, 08:12:57 AM »
Thank you, I am still not sure what the issue is. I also have a demo of drufelcnc that seems to run this program with out issue. But mach3 gets through the first few lines. Moves to the corner lifts tool but then does not come back all the way down to the work.
Logged
TPS
2,627
Reply #11 on:
April 03, 2023, 08:19:00 AM »
it may depend on the G17 G18 plane selection.
those make IMHO only sense in combination with G40-G42.
but as sayed, i am a G-code specialist.
i never used somthing else than G17.
Logged
leaddennis
9
Reply #12 on:
April 03, 2023, 08:20:18 AM »
I may have to rewrite the code, It works in grbl on my other machine. This code was written in F360, I am no expert at f360 though. Thank you so much for your help.
Logged
TPS
2,627
Reply #13 on:
April 03, 2023, 08:24:19 AM »
had a quick look to the GRBL G-Code list. G17/G18 are not included, so they are ignored i think.
Logged
leaddennis
9
Reply #14 on:
April 03, 2023, 09:11:13 AM »
That makes more sense, thank you. Probably going to have to rewrite unless I take the g17 / 18 out right?
Logged
Print
Pages:
1
2
Go Up
« previous
next »
