Hello Guest it is October 23, 2026, 01:02:14 AM
Author Topic: Rotary Axes in Radians vs Degrees?  (Read 14241 times)
Re: Rotary Axes in Radians vs Degrees?
« Reply #10 on: April 04, 2023, 12:10:48 PM »
its our software ,its for the woodworking industry its first software that can very easy desighn and sell furniture
and one click all opration included 5 axis  will run
all machine only with mch4 we use absolute encoder  via rs485 but the communication with the rs485 done by external app not by mach
in this way we granty all axess act almost as close loop
we cheack position in some critical points (background)and we know our precision exactly
only bad point i told here many times that i cant solve its the s curve
for now we do it by the servo driver but this very bad solution but its the only we have
without s curve acceleration mean almost nothing ,you need do so bad acceleration almost i give up mach only because that
i hope some one in mach will take this  challenge ahead
« Reply #11 on: April 04, 2023, 12:14:22 PM »
this our simolator its base on europe 3d WPF libary
« Reply #12 on: April 04, 2023, 12:23:52 PM »
i atach the parameter we use ,i suggest any any user of mach with cnc with rack& pinion try this
without this its almost cant do good job
you must make very very long acceleration and then cant do CV well ,cant simoltany 3 axis's together....
this parameter not good solution because you pass the system and have many situation hard to control
but without this.....for my opinion ....the machine its toy not machine
