Hello Guest it is October 24, 2026, 04:13:22 AM
Author Topic: Just starting out  (Read 25895 times)
Re: Just starting out
« Reply #20 on: February 01, 2023, 12:46:09 AM »
We totally different requirements
42000rpm? Our speed it's max 20000
But in other hand our min power it's 9kw
« Reply #21 on: February 01, 2023, 01:28:07 AM »
most of my paying work is high speed engraving and therefore 42000 rpm would be nice.
I also do quite a few small parts in aluminum, brass and steel with small tools, often less than 1mm in diameter. For such jobs
having a spindle with good toque at 18000 rpm would be nice, and the Mechatron Gmbh spindle I'd like could do that.
I have a second spindle that I can slip into the same mount. It's based on a 1.8kW, 6.1Nm cont, 3500rpm Allen Bradley servo driving an ER25
toolholder. This spindle I use for steel and stainless with bigger tools up to 16mm endmill's. It's manual tool change.
I have a project to build my own spindle. I have for this purpose a servo that dates from the mid 90's. Its 3kW, 14Nm cont at 4000rpm. It has a resolver
rather than an encoder so trying to find a drive was near impossible. Electronics is my thing so I'm building a Field Oriented Control driver for it.
I will pair that with an ATC. Given the slower speed probably BT30 or BT40. This project has been going on for years. At the moment with the two spindles
I have I can do almost everything I need so the impetus to make yet another spindle is modest.
My efforts and money is more directed to fur and five axis. You can only do a certain amount, and you need to focus your efforts to make progress.
« Reply #22 on: February 01, 2023, 01:37:59 AM »
I use Chinese spindle ,9kw it's the cheapest , because it's the most popular ,but I had several customer 9.5 it's too high ,and also they need water cooler ,so I bought also in chine  but it's 6kw only 18000 rpm and cost was 2000$ it's pas almost 2 years this machine work 3d working ( mean can work 2 days without any rest) and not one problem ,btu30 not iso
« Reply #23 on: February 01, 2023, 01:53:54 AM »
well you are probably right, I should buy a Chinese spindle, after all its all I can afford. My focus is on four and five axis,
and the ATC spindle will just have to wait.
« Reply #24 on: February 01, 2023, 01:55:33 AM »
If you need my help ( I have Chinese agent help me alot ) send me on private
« Reply #25 on: February 01, 2023, 02:03:15 AM »
thanks, but I'm not looking for a spindle. I'm focusing on four and five axis.
If I were to spend time and money on a spindle I will resume my 3kW servo driven spindle project.
