Hello Guest it is November 22, 2026, 03:24:59 PM
Author Topic: Output on one condition off if not  (Read 124657 times)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Output on one condition off if not
« Reply #10 on: January 22, 2023, 06:50:34 PM »
Outputs are latched under normal control so I would have thought Brains did the same.  I could be wrong as I do not use Brains much.
« Reply #11 on: January 22, 2023, 06:59:09 PM »
I take it latched means once turned on, it also needs turned off, because that seems fo be the issue i have ?
  •  2,785 2,785
« Reply #12 on: January 23, 2023, 04:26:24 PM »
Latched is locked into a fixed state until forced to change.  So my guess is you need to toggle the state in the brain or force a state to make sure you have the state you need.
« Reply #13 on: January 23, 2023, 04:29:50 PM »
Thats what i figured, and also what im having a hard time doing.  I will keep working at it.  I wrote some that i thought would work but they did not 🤔.
  •  2,785 2,785
« Reply #14 on: January 23, 2023, 04:52:11 PM »
I am not an expert at Brains, not needed to use them much but this is what I think should work.
« Last Edit: January 23, 2023, 05:23:52 PM by Graham Waterworth »
« Reply #15 on: January 23, 2023, 06:11:52 PM »
I tried one similar and it seemed to only use the greater than or less than condition, but ill give it another shot and see what happens, thanks for the suggestion.
« Reply #16 on: January 29, 2023, 03:26:18 PM »
I gave that a try, still no luck.  I would think such a small task would be simple.  Not sure what im missing.
  •  2,785 2,785
« Reply #17 on: January 29, 2023, 08:03:18 PM »
It works for me, try my file.
« Reply #18 on: January 30, 2023, 10:26:39 AM »
i tried yours, but you used 143 encoder count 3.  I used 170 encoder count 0 I believe.
That was the dro input number I found to correspond with the z axis DRO in the mach 3 settings tab.   The brain I built is identical to yours other than that.  The less than or greater than statements work fine as i toggle the DRO above or below the Z position, but when the encoder count, and z position match, I do not get the Encoder Count = Z position to work.  Where in mach 3 does 143 encoder count 3 correspond to?
