Hello Guest it is November 23, 2026, 03:20:01 AM
Author Topic: Backlash Compensation  (Read 11299 times)
« on: October 30, 2007, 09:30:09 PM »
We have  two Series II Bridgeports, both with measured backlash of about .002" in the Y-axis.  Is there a way to compensate in Mach 3 for backlash?
It's all fun and games till the Geckos die.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Backlash Compensation
« Reply #1 on: October 30, 2007, 11:53:16 PM »
Hi, Agwelder
Under Config, 9 Down "Backlash", Don't forget to enable it, Then OK and Re-Start Mach.
Do some testing to make sure it's cutting Properly, Try some circle's also to check it out, Been some issues over time.
Haven't used it myself
Hope this Helps, Chip
« Last Edit: October 31, 2007, 12:00:35 AM by afn09556 »
« Reply #2 on: October 31, 2007, 07:16:56 PM »
Thanks Chip,
We set up our Backlash comp. today.  In our test circle cutting we measured .0035 out of round with compensation off, and .0005 out with it on.  This really helped us out.
« Reply #3 on: October 31, 2007, 09:16:15 PM »
Also, shuttle accel on the general config page effects the way your backlash acts. Try setting it to .005-.01.
