Hello Guest it is November 19, 2026, 01:40:06 AM
Author Topic: G54 is changed in Z when using M6 tool change  (Read 48234 times)
Re: G54 is changed in Z when using M6 tool change
« Reply #10 on: October 25, 2022, 06:09:59 PM »
Hi. Comming back to this now. Was in the workshop today so I did some photos och the plugin .\Plugins\NcEther-8ts
Thanks and regards
Offline TPS
  •  2,627 2,627
« Reply #11 on: October 25, 2022, 11:21:42 PM »
pls check, if there is a file like this   C:\Mach3\Plugins\NcEther-8ts.m1s ?
« Reply #12 on: October 26, 2022, 03:17:30 AM »
There is a C:\Mach3\Plugins\NcEther-8ts 2.dll, see photo
  •  9,378 9,378
« Reply #13 on: October 26, 2022, 04:51:05 AM »
Hi Tomashi,
I have sent you a PM.
Offline TPS
  •  2,627 2,627
« Reply #14 on: October 28, 2022, 11:01:24 AM »
ok, it is a dll, and we are not able to "see" the macro code.
only thing what's left is to use a "selfmade" M6Start macro for the ATC.
here:
https://www.machsupport.com/forum/index.php?topic=36417.msg249874#msg249874
is an example i posted some years ao.
« Last Edit: October 28, 2022, 11:13:43 AM by TPS »
Offline kf2qd
  •  157 157
« Reply #15 on: March 22, 2023, 04:47:58 PM »
G54 sets the X Y & Z coordinates to your reference tool. One of the pieces of data you enter for each tool is the LENGTH.What is happening as you change tools the Ddiplay value for Z will change to reflect the currently called out tool. So - if for your reference tool - the Z position at a certain height of the machine is 3", then is you change to a tool that is an inch shorter and have an M6 T?? line matching the new tool, the Z value would read 4 reflecting the current position of the now active tool.
