Hello Guest it is November 10, 2026, 01:39:15 AM
Author Topic: macro correction 2  (Read 18830 times)
macro correction 2
« on: September 19, 2022, 02:30:13 AM »
Good morning
having time I am fixing my screenset, I have this macro internal external center that works well (taken from the network and modified to my needs) the only problem is that with the scan "A" ("TO EXTERNAL CENTER") the positioning takes place at maximum speed, then for the touch it works well, is it possible to change it by setting the positioning speed? is there anyone who can encourage me to correct it? I thank those who can help me
ps: the inner part ("B INTERNAL CENTER") works fine.
Code: [Select]
' CENTRO INTERNO ESTERNO
Sub Main
  If (GetOEMLED(800)) Then
Message ("ERRORE : MACCHINA IN EMERGENZA ")
Speak ("errore            macchina in emergenza") 'Avviso Vocale
Exit Function
End If
Speak (" CENTRO INTERNO ESTERNO") 'Avviso Vocale
 Begin Dialog SelectCentering 250,40,150,270,"SELEZIONA CENTRO"
   OKButton 20,245,40,15
   CancelButton 90,245,40,15
   GroupBox 10,5,130,57,"CENTRATURA",.GroupBox1
      Picture 5, 95, 140, 140, "c:\mach3\addons\centri_scan_sondaggi\bitmaps\centro A.bmp"
   text 15,68,180,8, " PS:   PER LA SCANSIONE ESTERNA "
   text 12,78,180,8, "POSIZIONARSI 5 MM SOPRA IL PEZZO"
   OptionGroup .OptionGroup1
   OptionButton 30,18,100,8,"A  CENTRO  ESTERNO",.OptionButton1
   OptionButton 30,49,100,8,"B  CENTRO  INTERNO"  ,.OptionButton2
  TextBox 20,30,50,12,.TextBox1
Text 75,31,50,8,"LUNGHEZZA"
  End Dialog
  Dim Dlg1 As SelectCentering
Button = Dialog (Dlg1)
  lunghezza = CDbl(Dlg1.TextBox1)
  SetOEMDRO 1824 , lunghezza
  If Button = 0 Then Exit Sub
  Selected  = Dlg1.OptionGroup1
  'CENTRO pezzo pieno is selected @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
  If Selected = 0 Then
Speak (" CENTRO PEZZO PIENO") 'Avviso Vocale
Tasto = MsgBox("CONFERMARE CENTRO PEZZO PIENO" ,1+64, "CONFERMARE")
If Tasto <> 1 Then
    Exit Sub
End If
Sleep (500) ' pausa di 1 secondi
 Message "**** zero assi ****"
   DoOEMButton (1008) 'zero X
   DoOEMButton (1009) 'zero Y
   DoOEMButton (1010) 'zero Z
   Call SetOEMDRO(1826,0)
Speak ("ZERO assi completato") 'Avviso Vocale
'CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
CurrentToolDiameter = GetOemDRO(1000) 'gets the current tool diameter
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Call ProbeGrounded()
    Exit Sub
Else
   Sleep (1500) ' pausa di 1 secondi
    XCurrent = GetDro(0)
    YCurrent = GetDro(1)
   ' OutsideDiameter = QUESTION ("DIAMETRO APPROSSIMATIVO")
     OutsideDiameter = GETOEMDRO(1824) ' leggi F di Spostamento
    Message "**** RICERCA ****"
    Code "G4 P1" 'Pause 1 second to give time to position probe plate
    While IsMoving ()
     Sleep(100)
      Wend
    Call SetDro (0,0.000)
    While IsMoving ()
     Sleep(100)
      Wend
    Call SetDro (1,0.000)
    Code "F50" 'slow feed rate to 100mm/sec
    Code "G90 G0 X" &XNew + OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe Left
    XNew = Xcurrent - 75
    Code "G31 X" &XNew
    While IsMoving() 'wait for the move to finish
     Sleep(100)
      Wend
    Code "G91 G0 X1 F10"
     Sleep(100)
      Wend
    Code "G31 X" &XNew
     Sleep(100)
      Wend
    XPos1 = GetVar(2000) 'get the probe touch location
    Code "G91 G0 X1 F50"
    Code "G91 G0 Z10"
    Code "G90 G0 X" &XCurrent 'rapid move back to start point
    Code "G91 G0 X" &XCurrent - OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe Right
    XNew = XCurrent + 75 'probe 75mm to right
    Code "G31 X" &XNew
    While IsMoving()
     Sleep(100)
      Wend
    Code "G91 G0 X-1 F10"
     Sleep(100)
      Wend
    Code "G31 X" &XNew
     Sleep(100)
      Wend
    XPos2 = GetVar(2000)
    Code "G91 G0 X-1 F50"
    Code "G91 G0 Z10"
    XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
    Code "G90 G0 X" &XCenter 'rapid move to the x center location
    While IsMoving ()
     Sleep(100)
      Wend
    Code "G4 P0.25"
    Code "G90 G0 Y" &YNew - OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe up
    YNew = YCurrent + 75
    Code "G31 Y" &YNew
    While IsMoving()
     Sleep(100)
      Wend
    Code "G91 G0 Y-1 F10"
     Sleep(100)
      Wend
    Code "G31 Y" &YNew
     Sleep(100)
      Wend
    YPos1 = GetVar(2001)
    Code "G91 G0 Y-1 F50"
    Code "G91 G0 Z10"
    Code "G90 G0 Y" &YCurrent
    Code "G91 G0 Y" &YCurrent + OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe down
    YNew = YCurrent - 75
    Code "G31 Y" &YNew
    While IsMoving()
     Sleep(100)
      Wend
    Code "G91 G0 Y1 F10"
     Sleep(100)
      Wend
    Code "G31 Y" &YNew
     Sleep(100)
      Wend
    YPos2 = GetVar(2001)
    Code "G91 G0 Y1 F50"
    Code "G91 G0 Z10"
    YCenter = (YPos1 + YPos2) / 2
Rem move To the center
    Code "G90 G0 Y" &YCenter
    While IsMoving ()
     Sleep(100)
      Wend
    While IsMoving ()
     Sleep(100)
      Wend
    Call SetUserDro (1826,YPos2 - YPos1 - CurrentToolDiameter)
    Message "**** RICERCA COMPLETATA ****"
    Code "G4 P0.25"
    Code "F" &CurrentFeed 'restore starting feed rate
   Call ReturnG90G91State()
   Exit Sub
End If
 End If
  'CENTRO PEZZO INTERNO is selected@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
  If Selected = 1 Then
    Speak ("  RICERCA CENTRO INTERNO") 'Avviso Vocale
Tasto = MsgBox("CENTRO INTERNO" ,1+64, "CONFERMARE")
If Tasto <> 1 Then
    Exit Sub
End If
'(M1055) Center Of Circle With Diamter
Message "****** CENTRO FORO ******"
Sleep (1000)
setvar(2000,0)
setvar(2001,0)
setvar(1,0)
setvar(2,0)
setvar(3,0)
setvar(4,0)
setvar(5,0)
setvar(6,0)
setvar(7,0)
setvar(8,0)
Setvar(9,0)
tmc=getoemdro(221)
setvar(9,(tmc/2))
Code "G91"
Code "G31X-70 F200"
While Ismoving()
 Sleep(100)
  Wend
Code"G1x5"
Code"#1=#2000"
Code"G31x140 F200"
While Ismoving()
 Sleep(100)
  Wend
Code"#2 =#2000"
Code"#3=[#1-#2]"
code"#7=[#3/2]"
Code"G1x[#7+#9]"
Code"G31Y70 F200"
While Ismoving()
 Sleep(100)
  Wend
Code"#4=#2001"
Code"G1y-.5"
Code"G31y-140 F200"
While ISmoving()
 Sleep(100)
  Wend
Code"#5 =#2001"
Code"#6 =[#4-#5]"
code"#8 =[#6/2]"
Code"G1y[#8-#9]"
While Ismoving()
 Sleep(100)
  Wend
Code"G90 M30"
HD= Getvar(6)
 Call SetUserDro (1826, HD + GetOemDRO (1000))
 'MsgBox ("Hole Diameter is " & HD + GetOemDRO (1000))
  End If
End Sub
Sub ProbeGrounded()
   Code "(Probe plate is grounded, check connection and try again)"
End Sub
Sub ReturnG90G91State()
   If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
      Code "G91"
   End If
   If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
      Code "G0"
   End If
End Sub
Re: macro correction 2
« Reply #1 on: September 19, 2022, 07:31:47 AM »
Very hard to understand your question as I can't see where scan "A" is, but I see a few places where you have code like this:
    Code "G91 G0 Z-10"
So first you set the feed rate to 50mm/min (not per second, and not 100 as the comment says!), then you do a G0 move which ignores the feedrate you have just set!  Should those G0s be G1s?
« Reply #2 on: September 19, 2022, 08:41:33 AM »
John Haine thanks for the answer, the comment was wrong with regards to G0 or tried with G1, but it was not that, I state that VB is not in my knowledge the part of the code concerned is:
Code: [Select]
Tasto = MsgBox("CENTRO PEZZO PIENO" ,1+64, "CONFERMARE")
If Tasto <> 1 Then
    Exit Sub
End If
   DoOEMButton (1010) 'zero z
   Call SetOEMDRO(1152,0)
    Exit Sub
Else
    'OutsideDiameter = GetUserDRO(1152)
    Speak ("DIAMETRO APPROSSIMATIVO") 'Avviso Vocale
    While IsMoving ()
     Sleep(100)
      Wend
    While IsMoving ()
     Sleep(100)
      Wend
    Code "F500" 'slow feed rate
    Code "G91 G0 Z-10"
Rem Probe Left
    Code "G31 X" &XNew
     Sleep(100)
      Wend
     Sleep(100)
      Wend
    Code "G31 X" &XNew
     Sleep(100)
      Wend
    Code "G91 G0 Z10"
    Code "G91 G0 Z-10"
Rem Probe Right
    Code "G31 X" &XNew
    While IsMoving()
     Sleep(100)
      Wend
     Sleep(100)
      Wend
    Code "G31 X" &XNew
     Sleep(100)
      Wend
    Code "G91 G0 Z10"
    While IsMoving ()
     Sleep(100)
      Wend
    Code "G4 P0.25"
    Code "G91 G0 Z-10"
Rem Probe up
    Code "G31 Y" &YNew
    While IsMoving()
     Sleep(100)
      Wend
     Sleep(100)
      Wend
    Code "G31 Y" &YNew
     Sleep(100)
      Wend
    Code "G91 G0 Z10"
    Code "G91 G0 Z-10"
Rem Probe down
    Code "G31 Y" &YNew
    While IsMoving()
     Sleep(100)
      Wend
     Sleep(100)
      Wend
    Code "G31 Y" &YNew
     Sleep(100)
      Wend
    Code "G91 G0 Z10"
    While IsMoving ()
     Sleep(100)
      Wend
    While IsMoving ()
     Sleep(100)
      Wend
    Call SetUserDro (1152,YPos2 - YPos1 - CurrentToolDiameter)
    Code "G4 P0.25"
   Exit Sub
End If
 End If
« Reply #3 on: September 19, 2022, 11:28:03 AM »
Well I'm sorry, but I am not going to crawl through the code trying to work out what it does if you can't point to approximately at what line it doesn't behave as you want.  There are some oddities - for example I see a feed rate of 500mm/min defined a few lines before a G31 as "slow feed rate" - that doesn't strike me as slow!  50 or 5mm/min would be for fine probing.
Though you may not be familiar with VB if you could learn how to single step through the code you could see and explain at which instruction it misbehaves it would be much easier to help.  Line numbers would be very useful too!
« Reply #4 on: September 19, 2022, 12:45:25 PM »
ok John Haine, thanks for your patience, it was my mistake the right line is: "Code" F50 "'slow feed rate" which should be the slow speed, and it works fine.
testing line line the problem arises on line: "Code" G90 G0 X "& XNew + OutsideDiameter * .6" starts at maximum speed, (this is the problem) when it reaches the probing point it switches to minimum speed and works well, touched the point gets up again (slow speed) it stops and to touch the next point it starts again at maximum speed then goes to slow speed to touch the point and here it works
« Reply #5 on: September 19, 2022, 12:49:09 PM »
I changed the "Code" line G90 G0 X "& XNew + OutsideDiameter * .6"
in "Code" G90 G0 X F500 "& XNew + OutsideDiameter * .6"
but nothing changes
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #6 on: September 19, 2022, 02:59:39 PM »
Change G0 to G1
« Reply #7 on: October 07, 2022, 04:27:35 AM »
thanks Graham Waterworth for the reply,
I replaced the line "Code" G90 G0 X "& XNew + OutsideDiameter * .6" with "Code" G90 G1 X "& XNew + OutsideDiameter * .6" but I didn't solve it, I also tried "Code" G90 G0 X F300 "& XNew + OutsideDiameter * .6 "the problem is not solved, it creates others. Thanks for your help.
